Hello,
I am working with the CanMV K230 kit and trying to connect it to a LAN network using a USB to Ethernet adapter.
Issue Description
According to the documentation, the kit supports adapters with the RTL8152B chipset. Since the original recommended adapter is not available in my country, I purchased a TP-Link UE200 (RTL8152B).
When I boot the device and follow the LAN configuration examples, the Ethernet adapter is not detected. The UART boot log shows:
In: serial@91400000
Out: serial@91400000
Err: serial@91400000
Net: No ethernet found.
Hit any key to stop autoboot: 0
System Information
- Image version:
CanMV-K230_01Studio_micropython_v1.2.2-0-g4b8cae1_nncase_v2.9.0.img - Runtime system info:
System Name: rt-smart
Node Name: rt-smart
Release: v1.2.2-4b8cae1
Version: v1.2.2 on 2024-12-18
Machine: k230_canmv_01studio
Request
- Is the TP-Link UE200 (RTL8152B) supported, or is only the recommended adapter compatible?
- Is there a way to access the rt-smart OS shell to reconfigure or load the Ethernet driver manually?
- Any possible workaround for faster testing before I can order the official recommended adapter (which will take a long time to arrive)?
Thank you for your support!
